I have some advice and tips for you, rb56.
The best thing I can say is to go on dslreports.com and search their forums and read up on Qwest/MSN, and then search for reviews of it in your area. At 1.5Mb/896k for
Qwest, surely people have reviewed that before.
In games, having a massive upload only helps if you have a download going or many other people doing many different things. When I had 1Mb/128k ADSL a while ago, I pinged 20-40ms everywhere, including the latest games. When I went to 2mb/256k charter (which is now 3Mb/256k), my ping was--you guessed it---still 20-40ms. The difference is that I can download a big file and the ping is okay, and I'm not impacted by the others on my home network anymore.
I'm about to finish up a degree on Networking and I can tell you that he could still lag in some servers on xbox live with a 800+kbps upstream rate because it all depends on your route and its quality. For instance, when my CS server's ISP was hit hard with a hardware failure, it routed all local (Minnesota, WI, ND, SD, Iowa) players to Seattle and back. We all had fine upstream rates, but the lag was terrible because a change in their routing tables forced us to take the "scenic route."
My other suggestion is to do pre-qual test on dslreports.com to see how far away from the Central Office you are. I've known people that were far far away from ours and still get 1.5-1.6Mbps of the 2Mbps they offer now as standard for DSL. Of course, this all depends upon the quality of the lines because I have also heard differently from other areas. In my area, it has been booming and the telephone company has aggressively laid down new fiber and has been building up the equipment quality to accommodate the users. I don't think the # of people in your area is going to affect you at all, especially with DSL. We have thousands and thousands of people in this area on Charter's cablemodem service and on DSL and nobody gets slow speeds, and Qwest for you has been trying to improve their service everywhere.
To recap, basically check out dslreports.com. You will get MUCH better results there on what to choose than here, as you can clearly see from the responses about how fast everyone else's DSL or cable is
😛. Secondly, you should go to
DSLreports' speed archive and enter in your ZIP code to see if anyone in your area has done speed tests, once you find the ISP you want to switch to.
Good luck!:beer:
