Originally posted by: Tiamat
Hey, thanks guys for the responses. The ceiling is pretty solid, certainly not sheetrock. I dunno if I need "perfectly" perpendicular. I am in the process of buying some acoustical panels which are either 18 lbs or 28lbs each. They will be hanging from wire that has to be secured to the ceiling, probably by some D-ring + Screw type things. I don't mind paying 80$ for a hammer drill if that is what it costs, but I do need to buy some bits.
I figured i needed a "jig" because I'm not very handy (last time I used power tools was in technology class in junior high school about a decade ago :laugh🙂 and I figured it would help esp because the ceiling drilling would be an awkward position.
Basically, the ceiling and floors are heavy/thick enough so that you cannot hear people walking above you. The walls are sheetrock and should be easy to drill through.
Can a hammer drill be used for normal drilling?
28 pounds each? How big are these panels? I'd think long and hard about this, if your anchor system fails, one of those panels will do some serious damage to your head. Is there a track assembly you hang then install the panels?
You need to know what the anchors are before you start drilling holes, and you need to verify that they will hold the load you're putting on them. The plastic expansion anchors aren't made for tension loads, you're going to have to use a wedge anchor of some sort.
