Drilling holes in PVC pipe...
PVC is hard to drill when it's at too low of a temp. I suggest heating it with a propane torch before drilling through it.
Originally posted by: Czar
I have no idea
but might try to put masking tape on top of it to get you starting, and start by making a small hole, then use the larger drill
Why masking tape?
if its a small pipe then the drill can easily slip, easier to keep it steady with a masking tape
Tape also helps reduce splintering and rough out.
Doesn't sound like it's an issue, but use twist bits if possible. If you need to use a spade bit, make sure it's sharp & go slow.
I had a bad experience along those lines.
I have no idea
Why masking tape?
I've found making a small divot first with a dremel helps with this issue as well.
Originally posted by: sharkeeper
Hmmm...
PVC is very easy to drill.
If you are a beginner, a drill press can give better results especially if the holes have to go straight through.
What's the diameter, schedule and application?
Its two inch diameter, not sure what you mean by schedule, and the holes are going to be threaded to fit metal nozzles which will converge 6 tubes to one larger tube.
Also, any tips on capping the ends of this pipe?
2 inch diameter hole? Then I would use a hole saw.
Use a condom and a hose clamp to cap the ends.
eeeeeeeeeeeeeeeeeexcellent...now that I just got some more nozzles from Ace its time to hit the lab. Thanks for the info people!
I have no idea
Why masking tape?
Did you notice the first sentence of his post?
still have no idea 😛
I dont want to mess up so I figured someone here would have some PVC experience and let me know the do's and dont's of working with it.
try a girlfriend first 😉
