Drilled a hole in my Air Conditioner
TheRyuu
5,479
14
It's a window one, is that bad? The water was just building up to insane amounts.
TheRyuu
5,479
14
Originally posted by: djheater
you should have stopped at a half.
Half of what?
Read up that some air conditnioner's throw the water on the hot....thing.
Not sure how it all works, but my older air conditioner had a hole in it.
Mike2002
290
Did the air conditioner not have a plug that would allow the water to be released?? And my window air conditioner acutally uses the water that builds up to help with the cooling.
TheRyuu
5,479
14
No it didn't.
If it did infact help with the cooling, would it hurt if there was a hole in it?
TheRyuu
5,479
14
Half of what?
Ugh. Whole != hole.
How is it that so many people confuse homophones like this? It really gets on my nerves for some reason
Yes, I know, I fixed it btw. I was typing to fast to notice it.
jimbob200521
4,108
29
I don't think it will hurt it, but you shouldn't need to drill one. Is your air conditioned tilted at all in the window? It should have a slight tilt to it to help it evacuate the water out of its predrilled hole.
Toasthead
6,621
Half of what?
Ugh. Whole != hole.
It really gets me when people dont understand sarcasm
Tom
is it install correctly ? some window air conditioners are supposed to be tilted slightly, not level.
TheRyuu
5,479
14
There was no predrilled hole. Thats why I put one there. I guess commen sense (meaning water+hole=get rid of all the water) doesn't apply here?
And yes, whenever I install an A/C I use a level to make sure it's slightly tilted.
And I'm just asking should I plug the hole up or not because I wasn't sure if it helped cool the air.
33,626
Half of what?
Ugh. Whole != hole.
Sooooo, does a homophone have a microphone at both ends of the handset? ;)
GalvanizedYankee
6,986
The pump that sends the water over the hot condenser probably failed. Normally the
water is evaperated and set on it's way with the hot exhaust air.
Drilling a hole to drain the water is OK, kinda ghetto but OK.
...Galvanized
