Originally posted by: BlackMountainCow
I have the same prob with ZoneAlarmPro. I have to shut it down completly in order to send my results. Only when u get that little chechbox ("results have been successfully send") your results were sent.
I might have an idea... hmmmmm
Do you by any chance know if muon1.exe is using internal code or an external program to ftp results to the server ??? If it is using an external program to send the results, then the solution might be to allow muon1.exe to use other programs to access the internet. It will be a while before I have a result file large enough to send, but then I will try.
If you are going to send soon, then maybe you will have a go at it ???
Just in case you don't know how:
- ZoneAlarm -> program control -> "Programs" tab
- Right click "muon1.exe" -> options
- Check "This program may use other programs to access the internet"
