Unforgiven
ive read the tutorial and in pm with dan he confirmed that all i needed to do was change the "threads" option in config.txt to 2 to make use of hyperthreaing....so my question is as follows: i changed the "threads" to 2 but yet i only see one instance in task manager of muon1.exe running using 100% of the cpu. why would there not be showing 2 instances of the muon project both using 50% of the cpu? for example i run seti as well and using seti driver i set my amount of processes to 2 and in task manager i see 2 of the command line client running, yet for DPAD im not seeing that. i know this may sound like a noob question but i wanna make sure that i am indeed doing this correctly and maximizing hyperthreading on my cpu.
