congratulations and welcome to the team!!!
are u using the command line version, the GUI, or the background version?
background/command line = fastest
remember to send ur results using manual_send every day..or 2 ..or 3 just incase HD goes bad or something else....
in the config.txt file u can set priority to B ...= background (only when program can take resources will it)
and u can set auto-save from default 180s to 60 s...
oh yes...have u gotten
best250.dat
basically all your results are saved in results.txt and results.dat...when u upload ur results the .txt file is deleted. the .dat file however remains...
as u gain results the algorithm modifies itself to produce better and better muoun transfers and to analyze more particles as a result..the higher the transfer + particles the better it is..
normally this is a self-running process. the best250.dat file however gives u the best 250 results as of october. these allow you to sort of get a "jump" on things...
download best250.dat from
www.stephenbrooks.org/muon1 its at the very bottom of page...unzip it and open it w/ notepad...
if u already have a results.dat in ur muon folder COPY..PASTE the best 250 into that file and save it...
if u dont (say b/c ur first unit hasn't finished yet) simply copy the best250 into ur muon folder....
phew...
