Wolfsraider
- Jan 27, 2002
- 8,305
- 0
- 76
Originally posted by: Overkiller
Wolfsraider-
I also noticed that the link at the end of this leads you to a 404. While the address is fine the actual link behind it is something like dpad.wolfsraider.www.stephenbrooks.org/muon1
so if possible could u also fix the link?
thanks man!!
[Should i always hop onto the latest version once it is released?]
-As the client is still in beta phase the roll-out of a new client version is beta unto itself. A good method is to run it, if it runs fine then you are good to go! If not switch back to your old version (making sure to copy over ur results.txt and results.dat) and go to the DPAD forums and post for Stephen. Usually he responds the same day. Once again the link to the main site is:
oops found the problem "leaving out http made it revert to dpad directory
field was added also
as far as spelling...my spelling checker doesn't seem to show anything..it usually balks at every http etc.. but not today
can you folks check it out and lmk if there are problems?
thanks
mike
