DPAD Daily Stats - 09.03.2004
OK, just replaced the 4.33 clients with the 4.34 clients. Lets see if that helps with the percentages. 🙂
Well I dont what the deal is but now machines are not sending up results. Did a manual send but I dont know if anything happened. Just got a momentary dos screen popped up and that was it.
are you trying to send the results by executing the manualsend in a shared folder on the network?
I've found that this doesn't work unless you map the share to some assigned drive letter.
example:
"\\machine1\c\program files\muon\manualsend.bat" is no good while something like "M:\program files\muon\manualsend.bat" would work (assuming you mapped the C share on machine1 to the some drive letter on the machine you're attempting to execute the manualsend.bat on)
This was a far guess tho, so I may not even be assuming your situation correctly at all 😀
How big was your results.txt file when you attempted the send?
example:
No, its installed exactly like 4.33a was. I think the problem may be that I didnt delete the original 4.33a program. Ill have to play with it tonite and see where I screwed up. It just doesnt seem to communicate with internet for some reason. Thanks for the input.
Deleted both RAR versions and reinstalled in the Program files directory of both computers using zipfile version. Hope that fixes it.
I actually had the exact same problem when I didn't delete the 4.33a version first... Completely forgot until you mentioned it 😉
Good find 😀
