- Apr 14, 2008
- 854
- 4
- 81
Im currently using a QX2710 monitor 1440p @ 97hz, running on my 290. My new RX480 only has HDMI and DP. Are there any adapters out there that will allow me to use the 480 and still OC my monitor, or will I be stuck at 1440p @ 60Hz?
Update 7/14/16:
Unfortunately I've had no luck getting an adapter to work on my 480 + Qnix2710. I tried two different adapters, both listed as being "Active" and supporting up to 4k @ 30hz. Both were of the non-powered variants. I picked one up from Microcenter, one from Amazon. The one from amazon has a handful of reviewers whom it worked for using the same monitor. They both exhibit the same flickering horizontal lines across the screen. Even picked up a spare DL-DVI cable to use with the adapters to make sure that wasnt the issue.
Update 7/14/16:
