Originally posted by: Vic
Originally posted by: raptor13
Assuming your example track car still has a synchomesh tranny, why is double clutching on the downshift necessary? You might be able to do it just to do it in the time it takes to rev match but if you're already heel-toeing... what's the point?
Double-clutching in a synchromesh transmission is almost never necessary, and does nothing without proper rev-matching. Both double-clutch and rev-matching are unnecessary for normal street driving, but can increase clutch and transmission life, and (when performed properly) provide for smoother shifting for yourself and your passengers' comforts.
How double-clutching helps is this: when shifting, there are separate 3 spinning components to be controlled, not just 2 like most people think. There is the engine, the transmission input shaft, and the tranmission output shaft. Rev-matching only matches the engine speed to the output shaft speed (as reduced or multiplied by the transmission gearing). When the clutch is in and the transmission is in neutral, the input shaft is free-spinning. Proper double-clutching allows you to increase the speed of the input shaft as well as the engine speed with the throttle blip of the engine rev-match.
In sequence: clutch in, shift out to neutral, clutch out, blip throttle rev-match (both engine speed and input shaft will be increased with clutch out), clutch in, downshift into appropriate gear, clutch out.
Personally, I only double-clutch for downshifts into 2nd and 1st (and I very rarely downshift into 1st while moving, only when absolutely necessary), as the differences in ratios and inertial masses are highest for those gears.
