deal of the day
Image Type - Non-interlaced
Max Resolution - 1600 x 1200 ( multiscan )
Dot Pitch - 0.26 mm
Diagonal Size ( Viewable Size ) - 19" ( 18.0" )
System Requirements - None
Device Type - Standard display / CRT conventional
Warranty - 3 years warranty
Power - AC 100/240 V ( 50/60 Hz )
Dimensions (WxDxH) / Weight - 44.7 cm x 45.5 cm x 45.2 cm / 20 kg
Price is $249. Use a $30 off $150 to bring it down to $219 for a 19" monitor. Lowest price on pricewatch is $279+$41(shipping). Sounds good. Whatcha'll think?
Dot Pitch - 0.26 mm
