Chadder007
Anyone up for Win3.1 and IE. 4.0 16 bit with web integration?
Originally posted by: Mucman
Nohr, I got my TEMP variable mapped to a RAM drive. This makes everything nice and fast, but it means the cache is destroyed when I power down. Browsing is a tad slower because it converts all images to bitmaps, but once cached, the thing flies! Anandtech comes pretty darn fast for me.
Originally posted by: ChefJoe
That laptop probably screams with dos on it. My P150 Thinkpad with 48 mb of ram is what I'm typing on here at work...... so slow, win98se.
Not at all Mucman, no suffering here 🙂. All worthwhile reading. Just intrigued at the thinking that went into it and the troubleshooting that took place. Having you explain it helps me decide whether I should give it a go or avoid banging my head on the desk 😉 Pretty cool work. Thanks for taking the time to post and follow up!Originally posted by: Mucman Sketcher, everytime I do some sort of computer project, I look back and regret that I didn't journal the whole ordeal 🙁. I spent two full evenings getting this to work, so there were a lot of things that I had to troubleshoot. If I leave out all the troubleshooting I did, the process went like this :
oLoad NIC packet driver
oStart Arachne
Yes it is that simple 🙂. Of course, I had issues with my PCMCIA card reader in DOS, changing data types in the NIC's config utility, figuring out that my caching nameservers wouldn't resolve, adding I=B000-B7FF to emm386 gives me an extra 32K of UMB 🙂. The largest amount of time was realizing that I didn't need the Win Client 3.0 software installed (which lowered my conventional memory to 450K). There's more, but I don't think you need to suffer through the other bonehead mistakes I made 🙂
Nohr, Sure you can! You could make a 4MB RAM Drive with that thing. What else is the RAM going to be used for? Remember that DOS isn't a multi-user/multitasking OS so when you are running something, all free memory is available to that application (unless running some sort of multitasking software).
