Humpy
Nor does not seeing any become a proof they are there. I was actually at the hardware store picking one out a month ago. You could see the backs of them and that there were no screw holes or screws included.
Most of them do not have fasteners and their installation guide does not suggest this. Of course one that did have fasteners and holes would mention it.
Depends on your definition of makes sense. The majority aren't fastened into concrete on new installations and don't come loose until either the wood core rots out or the frame does. It would then follow that it makes no sense to go to extra steps to *fix* something that isn't a problem.
However, let's dig into specifics. Here is one that looks like the pictured threshold. It may or may not be exactly the same but it is still an example of one of many that don't have mounting holes or hardware:
http://www.homedepot.com/p/Frost-Ki...er-Brown-Fixed-Sill-Threshold-TS36A/100207958
Notice there aren't screw holes and the vinyl trim is not designed to be popped off the top and snapped back on so it would hide any, rather it slides into the channel from the side during manufacture and is stapled to the back.
Did you read the page you linked to?
The first review says something about the instructions asking for the vinyl to be removed in order to install fasteners. I'm sure you could find some even shittier products to link to if you tried. Maybe even post a link to some of Frost King's instructions if you are feeling up to it.
I've installed hundreds of thresholds, I'm sure Greenman has as well, and I can only think of maybe one instance (unknown location of radiant heat) where it made sense not to screw them down. It is the simplest part of the job.
