Doom3 and My System
Mir96TA
My Hardware
Dell SC400 Server
Set Video Setting for MaX perforamce
Cpu=3 Gig 1Meg Cache 800FSB Presscott (Retail)
ChipSet=Intel P875
Mem=1Gig Dual Channel DDR 800FSB (PC3200)
Video=ATI 9500 with Omega Driver
Sound= SB Live 5.1
3D mark Test Result
System Configuration
General Information
Operating System Microsoft Windows XP
DirectX Version 9.0b
Mobo Manufacturer Dell Computer Corp.
Mobo Model 0F1425
AGP Rates (Current/Available) 8x / 4x, 8x
CPU Intel Pentium 4 2992 MHz
FSB 800 MHz
Memory 1022 MB
Display Information
Graphics Chipset ATI RADEON 9500
Driver Name RADEON 9500 (Omega 2.5.58)
Driver Version 6.14.10.6458
Driver Status Non WHQL - Not FM Approved
Video Memory 64 MB
Core Clock 353 MHz
Memory Clock 309 MHz
Sound Information
Sound Adapter Driver Name SB Live! Audio [CF20]
Sound Adapter Driver Version 5.12.2.252
Benchmark Settings
Program Version 3DMark03 Revision 4 Build 0
Resolution 1024x768@32 bit
Texture Filtering Optimal
Pixel Processing / Antialiasing None
Post Processing false
Vertex Shaders Optimal
Main Test Results
3DMark Score 4485 3DMarks
CPU Score 661.0 CPUMarks
Detailed Test Results
Game Tests
GT1 - Wings of Fury 168.7 fps
GT2 - Battle of Proxycon 25.4 fps
GT3 - Troll's Lair 24.8 fps
GT4 - Mother Nature 29.7 fps
CPU Tests
CPU Test 1 74.0 fps
CPU Test 2 11.7 fps
Feature Tests
Fill Rate (Single-Texturing) 951.1 MTexels/s
Fill Rate (Multi-Texturing) 2617.0 MTexels/s
Vertex Shader 16.7 fps
Pixel Shader 2.0 44.8 fps
Ragtroll 18.3 fps
Sound Tests
No sounds 67.6 fps
24 sounds 56.2 fps
60 sounds Not Supported
I guess I can use VIdeo card is a bottle necking
If I were to upgrade the Video card; What Video card I should go with it.
800x600 Medium with a bit of AA and you'll be fine.
I have:
AMD 1900+
512MB PC2100
GeForce 4 Ti 4400
Everything at stock, and I play at 800x600, medium detail, 2xAA, 0xAF. It runs plenty smooth, even through battles. To be fair though, I have optimized my system VERY well (I have 12 active processes on boot, that's it), keep it clean and in order, and have used tweakguide.com's Doom 3 tweak guide to adjust it perfectly for my system.
If you have everything in order though, you should be able to run it with plenty of detail.
heeee
I dont feel so bad now;
Cause People have $400 card and fighting with FPS......... I thoght I may not able to play
Cool 🙂
In advance PLEASE STOP POSTING, "WILL MY SYTEM RUN DIII?"
THe people who regularly post in the video forums cannot keep answering relatively the same questions over and over. You could either do a search in the video forums or you could look at the many DIII performance analysis ratings out there. AT and |H| have some good ones. Also in the forums Keys has put together a really nice one.
To answer your question, your Video card is going to be your bottleneck as it only has 64mb of texture memory (ie Video Memory). Therefore you need to allocate a loarge amount (ie 256mb) for AGP aperture to get it to run decently because of the frequent texture memory overflow. So your main bottleneck is your Graphics card however the PRescott CPU is only good if you are doing 2 things. Encoding/Decoding (with SSE3 optimizations), or OCing with exotic cooling (ie Phase Change, Dry Ice, Liquid Nitrogen) as you can get clockspeeds in excess of 4ghz. SO basically your CPU is your second bottleneck.
However i am curious as to how a 64mb 9500Pro is getting that many 3dmarks.
-Kevin
-Kevin
As you may have already noticed; Its Dell
U can't OVER CLOCKED a DELL 😛
and I promise its a ATI 9500 64 which is a Non Pro Video card
o jeez.. I guess I can't play that game.. 🙁 my p4 2ghz with a gefoce2 won't stand it even at 640x480 I guess.. is there any cheap alternative videocard upgrade so i can play the game decently smooth? like 30fps??
4200 at med quality or 9700 at high quality
