archcommus
Well my Windows password is typed by me frequently, like every time I boot up my system, or every time I lock my system and come back, etc., so I'm simply not going to make it 20 characters long with letters, numbers, and symbols. It needs to be quick and easy to type and I'm not really worried about the physical security of my system.
With that said, it's pretty obvious then that using EFS is not the right choice for me, since not only is the base key my Windows password, but it could possibly be found unencrypted in various places on my system. So using something like TrueCrpyt is probably the right way to go. But when the files get backed up to my external hard drive, where no programs are installed at all, what happens then? Are they still encrypted? But yeah in that case I'd probably use a 20 character key with letters, numbers, and symbols.
Also, an additional question - my passwords for websites and such are usually like 10 characters long or so with letters, numbers, and symbols, so according to that equation from Wikipedia that provides about 65-bit entropy. Is this good? I mean it's not like I could make it much better than that anyway, many sites limit password length to anywhere from 8-12 characters. But should I increase the ones I can to 12-16 characters? I'm guessing that's not really necessary.
