cmdrdredd
- Dec 12, 2001
- 27,052
- 357
- 126
Originally posted by: adondeeres
Originally posted by: Fallengod
Either bios settings or motherboard. Theres nothing else to blame. Theres no way its the memory. Sorry but no way. Firestix can do 1000mhz easy. All of them, every single one. You didnt buy them at microncenter did you?![]()
It could be bios settings. If you too tight of timings or something holding you back. Voltage? Hard to say. I dont know what to make out of those strange settings. It will do 400mhz but not 378? Or 425? That doesnt make any sense. Even the worst possible memory chips can overclock past 425mhz.And these are top memory chips were talking about.
I dont have too much experience with all different types of c2d mobos but, I thought the P5B deluxe was decent?
I bought these towards the end of February this year at Newegg. I haven't tried it at 400x8 yet. I will try it later tonight and keep everyone updated. All I know is that it has failed 378x9 and 425x8 at various settings, including the rated: 2.1V and 5-5-5-15.
Everyone: please let me know if there are any other settings/voltages at all from my BIOS that I can provide.
Last night, I tried to loosen the timing down to 6-6-6-18 @2.1V, but something happened and scared me so I won't be trying that again. It posted, but shortly thereafter, I get this screen that looks like I was in the BIOS (based on the .5 inch blue gradient strip at the top) and it just said "WAIT...". I left it like that for a minute and it didn't do anything. I turned off the power for 10 seconds, which is what ASUS recommends to activate CPR (I think it's called CPR) and turned it back on and hit the 'delete' key to go directly into BIOS, but same thing. Then, I turned off the power for a few minutes and was finally able get into BIOS. Strange. Possible sign of a mobo problem?
I'm using the final BIOS version which allow roll back. I think the later versions do not allow roll back to earlier BIOS versions.
Just a quick note that I did not mention...between 350 and 400Mhz FSB my board will not be stable, between 400 and 425 it's ok and between 460 and 503 it's ok too.
Maybe something similar for you? They're called "Black Holes" but I had assumed they were fixed...I just use 400Mhz FSB.
