Does the Shuttle AN35N-400 have PCI lock?
fwtong
695
How do I find out if the Shuttle AN35N-400 have PCI lock? Also, an unrelated question, does onboard LAN suck off CPU cyles like onboard sound?
jdogg707
6,098
check in the BIOS to see if you can lock the AGP/PCI bus to 66/33. Onboard LAN doesn't hurt you very much at all, if any really. Especially on newer processors.
jdogg707
6,098
Originally posted by: shminu
what do you mean by "lock"? I really want to know.
The AGP/PCI lock, keeps the AGP/PCI frequency at 66MHZ (AGP) / 33MHZ (PCI) when you increase the Front Side Bus.
robcy
503
Yes, it does maintain the correct AGP/PCI frequencies no matter what the FSB is. You can change them if you want.
The onboard lan has a seperate chip, so I do not think it will consume anymore cycles than anyother add-on LAN card.
fwtong
695
Thanks, but I wasn't able to find anything in my bios regarding AGP/PCI bus. Any ideas where it's at?
Thanks
