Originally posted by: DEMO24
yeah I was like wtf. but then I figured you knew what you were talking about 😛
and in the period I did it I only dropped 2 😉
and Ill ping the modeom some day when I think aobut it. takes to long to reboot the comp 🙁
pinging your LAN router should never, ever, ever be more than 10 ms, if it is you have a cabling/nic/driver problem.
Originally posted by: BatmanNate
I used to have a problem with my comcast service using an RCA modem where use of the television in close proximity would hump the connection. Apparently, the older models weren't shielded properly. They came and replaced it with a newer modem, which I think is a Motorola, but now the internet cuts out for a few seconds every few minutes and is driving me batty.
ping (gatewayIP) -t
wait 1 minute
<ctrl> C
Call comcast's customer service and report periodic service disruption. Tell them that you're dropping packets to your gateway and remind them that your modem was recently replaced.
I'll try it when I got home since I can't SSH in from work because the whole thing appears to be down now. And calling Comcast's tech support is only slightly more enticing than eating cakes of ground teeth. 🙁
fixed
ping (gatewayIP) -t
wait 1 minute
<ctrl> C
hahaha - well, you're going to have to ping your default gateway anyway. The second you say "speed problem" they're going to have your ping it anyway. 😛
im running XP. I have a 4 port Linksys router hooked to the cable modeom. Just my comp is picky and Iv found only works if I reboot when I go to cable modeom
fixed
DOH!
I slipped.
fixed
DOH!
I slipped.
Yeah, don't make me slap you around a bit with a large trout.
That's the thing--it's not actually a speed problem, when it's up it operates at normal speed. The only problem is that seemingly at random, as often as every 5-10 minutes, there is a lapse of 10-15 seconds where the connection is completely dropped. That's a problem when a streaming server operates over the connection, and it's a major irritation for surfing/downloading/or doing anything that requires continuity.
well, if you wanna slap me around with a trout bring your butt over to the networking forum where I live and get served.
Originally posted by: OulOat
Nik, you are losing your touch. I'll start you off. WRONG _____________
ping (gatewayIP) -t
wait 1 minute
<ctrl> C
/me slaps forehead. Someone slap ME around a bit with a large trout!
That's another issue, but they'll have you ping your gateway anyway. There's LOTS of things that could be causing that. Micro bursts of data from a roof-top satelite close by, cordless phone or other radio device being used too close to coax/cat5/modem, someone jumping up and down too hard in the house with a loose coax/cat5 or something 😛 That would take someone coming out to the house to fix, almost guaranteed.
Does it happen when you plug that PC's cat5 into another PC?
The problem exists for all of the PC's on the network, 3 servers, 2 workstations, and a variety of portable devices operating on wifi. It's most notable on the streaming server obviously, which is actually running on virtual hardware (debian is running in a VM layer under 2k3 server because the file server's RAID-5 arrays were originally formatted NTFS but I wanted to run Ampache under linux so they're both using the same NIC albeit different IP's, and the linux box actually streams from SMB mounts on the same physical machine but the files are located in the windows layer so it has to go through the network to itself to accomplish this--very convoluted but it works. Anyhow, I am rambling on about something that doesn't have anything to do with the issue at hand, I'll try pinging the gateway when I get home.
Yes, I know. 🙁 This should probably go into General Hardware or possibly Tech Support, but I'm tired. I'm cold. I'm hungry... and I'm not quite cranky enough. 😛
And not only are you not fixing the problem, you are helping the problem. Shame shame, never thought you would sink so low 😀
Bat, what cable medem setup are you using? Are you going throuh a router? I've heard of this problem with certain hardware versions of linksys modems, and with certain models of routers, and with certain NICs. And what program are you running (that uses your net connection) while this occurs?
And can you bring up your cable modem page? Try http://192.168.100.1 look at the signal page, note the downstream power, and SNR, and what QAM (64,128,256) modulation it is on.
