Does shaving your pits help with the sweat?
MrCodeDude
13,674
Hyperhidrosis. Ask your doctor about some over the counter solutions.
I am using a Old Spice Deoderant (not Antipersperant) + Certain Dri at nights and am not sweating near as much as I used to.
MithShrike
3,440
I don't shave my pits but I do trim the hairs. The shorter the hair the better my antiperspirant works.
Drakkon
8,401
ditto here...great combination (old spice+certain dri) ;) keeps the sweaty pits away
and dont shave if your goign to use certain dri...it will irritate the pors like crazy and you'll end up with a horrible rash...its not pretty and everyone will wonder why your going around with your elbows up in the air...:p
alm4rr
4,390
shaving won't help... hair helps wick the moisture off and away from your skin...
SLU MD
471
check out certain-dri as per the first reply. thats the most powerful stuff you can get without a Rx. it works wonders.
as for shaving, that will help w/ the odor, but not the amount of sweat. It may appear that you sweat more b/c there is no hair to cover up some of the liquid.
slu M.D.
Juice Box
9,615
Apparently you can now get BOTOX to cure excessive underarm sweating...that surprised me
Mani
4,808
Originally posted by: fs5
First of all, I shower everyday, twice a day sometimes. I'm 6', 200 lbs. Anti-perspirant & deoodrant helps but only for a few months at a time.
Then I have to switch brands because I guess my BO is so powerful it adapts to it! :( I've cycled through Degree, Axe, Sure, and Right Guard (all solids).
The smell of your sweat can be very dependent on diet. Try experimenting with different foods.
fs5
11,774
Okay, I trimmed them suckers down and it appears to have helped the last 2 days. It might be that the deodorant is getting on the skin now instead of just clinging on the hairs.
If not, I'll go get some certain dri. Thanks for the tips guys!
Shawn
32,236
53
Originally posted by: jaysgirl
Shaving your pit hair won't make you sweat any less, but it will help with any body odor problem you have. The hair keeps the moisture in and allows for bacterial growth.
I think this was why the ancient Egyptians shaved under their arms because they realized it would make them smell better. See?
wow, everything I ever wanted to know about B.O. and then some.
bracut80
160
what would a doctor do? Give a prescription? Examine my diet? Just curious.
he will give you some drops to put under your arms. i had the same problem. i forgot what the medicine is called but i will check when i get home.
basically shower before you go to bed. make sure you dry off good before you apply the drops. apply a few drops to each arm pit. in the morning take another shower and apply deodorant as usual. it only took a few nights and i was fine. if it comes back where i sweat and the deodorant doesn't work then i apply again. i had the problem for a few years, got on the meds and for the past 3 years i only had to apply 3 times. basically the drops kills the bacteria that is growing in your arm pits.
LtPage1
6,311
why dont you just carry your deoderant with you, and reapply partway through the day?
