DigDog
- Jun 3, 2011
- 14,274
- 2,736
- 126
How does that work with the mods/hacks for 32-bit that lets you use more than 4gb just doesn't let any particular program use more than 4gb?
you're thinking LBA48, not ram, but storage space.
I'm not sure how it's actually implemented, but isn't VRAM being used as a shadow copy of the data in (virtual) system RAM, when available, plus extra RAM that the GPU accesses via PCIe in case of missing data in VRAM?
Even though they only tested console ports that don't require much ram, they at least recognize that people might need more for non gaming reasons.8GB is probably the safest bet, not because it adds much to performance, but because it will allow you to do more with your system. As for 16GB - we'll stick to our guns here. We might run it in our test rig, but in no way, shape, or form do we recommend it to users who are only interested in maximizing gaming performance
If you get low memory warnings with 16GB, something is seriously messed up with your Windows install. I never got them even with my old system with 4GB of RAM. In fact, you're not supposed to get any warnings from running out of physical RAM. It should just transparently begin to page data to disk, which will of course reduce performance significantly but not cause any error messages to appear.
4GB is not optimal for gaming. A lot of newer 32bit games are LAA and will push 4GB usage on 64-bit Windows, especially with custom assets. The same applies to source ports of old games that use new content.
Even if you run a lean system, you’ll have nothing left for Windows if the game is pushing 4GB by itself. So 6GB is better, but 8GB is the optimal sweet-spot, especially with current prices.
Gamebryo and CryEngine games will push 4GB if you load custom content (e.g. texture packs, mods, etc).Which games?
I often get a warning message from window saying it has ran out of ram on my 16GB system due to browsers alone, and I need the browsers open when gaming as I typically game in borderless window mode to have quick access to guides and walkthroughs and the like
Don't happen to have your pagefile disabled, do you?
Next gen consoles have 8GB RAM (irrespective of type), their OS's are almost guaranteed to be 64-bit only, more and more console ports will be developed with that memory in mind.
I've worked in places where I've had to have 30-50 pages open at 1 time, on a single browser on 2GB of ram and a P$ at 3.6GHz, all running smoothly. I can't imagine a situation you'd need 3 browsers open at once.
How many years ago was that? My work laptop and my dad's PC both have 2GB of ram and can barely handle 5 pages, much less 50.I've had to have 30-50 pages open at 1 time, on a single browser on 2GB of ram
This year
I do not have it disabled. It is set to 1GB
Weird, you must go to really light sites then...
That or maybe you are doing a ton of paging? What browser are you using? In chrome you can hit shift+esc and then click "stats for nerds" to see the memory consumption of chrome, firefox, and IE
No, it should be however much you actually need.??? Page file should be at least equal to you installed ram size.
Because windows defaults to 1.5x the amount of physical RAM you use, which on a 16GB of RAM machine is 24GB, which is a huge chunk out of an SSD drive.I'll never understand why people mess with it?
I can about guarantee you let windows manage your pagefile and your errors will go away!!!
Edit: I have 170 pages open now = ~ 2.2gb
some of us choose to run without a pagefile. why? because ssd is slow.
if running out of ram. just buy more physical ram. pagefile is a bandage for not enough ram.
Are you saying running a page file on an SSD is slow?
I'm sure I've read several articles that have proven that not having a pagefile makes windows a bit slower in some tasks than even just having 100MB.
Something is seriously messed up with your browsers then.Of course there is nothing wrong with my windows install. I checked memory usage and it is all used by my browsers (as I explicitly stated before). Split about evenly between chrome, firefox, and iron (chromium derivative). well... used to be split evenly, I am carefully culling my firefox windows to keep its usage at a minimum to avoid this problem
Restarting all 3 browsers with a "reopen last windows/tabs" option reduces it a bit as there are memory leaks, but its still over 10GB used.
Uh, what? Are you even aware how pagefile works, and that the IO operations are small enough so it doesn't matter at all?some of us choose to run without a pagefile. why? because ssd is slow.
