Does LG E2240s LED Monitor Good?
miro2011
7
I Need to buy a new Monitor for Multitasks and I found this Monitor LG E2240s LED.
Does this good? What is the advantages and what is the cons?
Please help me.
miro2011
7
I found these Specs:
Response time: 5 ms
Display brightness: 250 cd/m²
Display diagonal: 22 "
Number of colours: 16.7 M
Pixel pitch: 0.248 x 0.248 mm
Viewing angle, horizontal: 170 °
Viewing angle, vertical: 160 °
Contrast ratio (typical): 1000:1
Aspect ratio: 16:9
Digital horizontal frequency: 30 - 83 kHz
Digital vertical frequency: 56 - 75 Hz
HDCP: N
Display resolution
Display resolution: 1920 x 1080 pixels
Connectivity
VGA (D-Sub) ports quantity: 1
DVI-I ports quantity: 0
DVI-D ports quantity: 0
USB 2.0 ports quantity: 0
Audio
Built-in speakers: N
Video
Full HD: Y
Camera
Camera included: N
Energy management
Power consumption (standby): 1 W
Power consumption: 23 W
Power consumption (off): 0.5 W
Colour
Colour of product: Black
Weight & dimensions
Depth: 55 mm
Height: 404 mm
Width: 529.8 mm
Weight: 4283 g
TV tuner
TV tuner integrated: N
Q:pixel pitch: 0.248 x 0.248 mm will Produce Good Quality Image and Text?
Q2: Does VGA D-Sub Connector will affect on Video Quality?
Borealis7
2,901
205
Don't worry about pixel pitch, its just the result of spreading 1920x1080 pixels on a 22" (diagonal) display. No DVI is a bigger problem.
miro2011
7
Thank you all so What's your advice about that:::
In My country in egypt These monitors only in our markets:
  • ASUS 23" LED MS238H /16:9 / 2MS / HDMI /1920*1080
  • SAMSUNG LED PX2370 23" 16:9/DVI+HDMI/1920:1080
  • SAMSUNG LED PX2350 23"/DVI+HDMI/1920:1080
  • SAMSUNG LED EX2220X 21.5" LED 16:9/D-SUB+DVI/1920:1080
  • SAMSUNG TOC 23" P2370MS /16:9/DVI - HDMI - video in - remote control/1920:1080
  • SAMSUNG 23" B2330H 16:9 /DVI+HDMI/1920:1080
  • viewsonic Led vx2450wm 24"/Dvi/1920:1080
  • SAMSUNG 18.5" B1930 /DVI /1366:768
  • BenQ 18.5" G922HDL LED 16:9/1366x768
  • samsung syncmaster b2030 20" /dvi/1600:900
  • SAMSUNG LED BX2031 20"/DVI/1600:900
which of these is better
sandorski
70,806
6,362
I use the first monitor on your list, but have no experience/knowledge of the others. That Asus is a very nice monitor though, but the Stand is not the best and could be a problem for you if you need to adjust it regularly.
miro2011
7
What's your opinion Which better resolution 1366x768 Or 1600:900 Or 1920:1080
in movies and reading text
tweakboy
9,517
www.hammiestudios.com
LG is a cheap Chinese company. Their stuff sucks,, and displays will die or be defective. A TV will die , its just cheap parts from China dont buy
Buy
Samsung ,, Korean
Sony Korean
gorobei
4,039
1,535
Buy
Samsung ,, Korean
Sony Korean
Do you ever ponder how worthless most of your posts are tweak?
http://en.wikipedia.org/wiki/LG
LG Corp. (Korean: LG 법인) is the second largest South Korean conglomerate company, headquartered in the LG Twin Towers in Yeouido-dong, Yeongdeungpo-gu, Seoul.[3] LG produces electronics, chemicals, and telecommunications products and operates subsidiaries like LG Electronics, LG Display, LG Telecom and LG Chem in over 80 countries.
miro2011
7
some people is saying that If you bought LCD Forget to watch DVD Movies The image will be like it taken from mobile
is this true?
