Pedroc1999
If you get the 5800k then yes. It has an unlocked multiplier which will let you OC it in the future to squeeze more power out of it
Physical cores and logical cores describe chips with Hyperthreading. The logical core does not occupy any die space; it is "within" the physical core.And if your not convinced look at the fx6300 and the 1090t 6core. The fx can actually outperform/match it in performance. Even thouh it has only 3 physical cores and 3 logical
Well, it might be something about leakage or something, but the clockspeed and voltage still play big roles in CPU power consumption.Won't the 5600K still consume more power, even at the same clock speed as the 5500? I was reading somewhere that the CPUs that cannot meet the 65w requirements are made into the 100w versions.
This has been argued to death. The performance of these chips are similar to their PhII quad core counterparts and they're mostly considered a quad core. Yes they have only 2 floating point units but those 2 floating point units can do as much work as 4 of PhII's floating point units hecause they are more efficient and that's why they perform like a quad core.
