John3850 [first]!! How would I KNOW if it's a ground contact?! I agree that there may be more than one pad devoted to the same ground, but even if they labeled those little gold pads, I'd need an electron microscope!!
Did anybody ever document which pads are either unused or grounds?
The pin out spec for the Core i7 2700K is here on page 90:
http://www.intel.com/content/dam/ww...eets/2nd-gen-core-desktop-vol-1-datasheet.pdf
And on the general topic of the thread, I work for Intel as an engineer, and I have spent a lot of time involved in the manufacturing and test aspects of our designs, and I have a lot of hours logged in the high-volume testing machines writing and optimizing test programs. And based on my experience I can say with absolutely certainty that every CPU that comes out of Intel is tested at a minimum of three times with increasingly larger and more complex test programs that are designed to check the correct operation of every transistor (at least that's the goal) and all of the pads on the package. I can easily imagine a manufacturing packaging visual defect (like a discoloration) slipping by - we don't tend to visually inspect each CPU for things other than gross defects - but I have a hard time trying to figure out how a serious electrical issue like a package pad being an open circuit would slip past. I guess it's possible - in quantum theory all things are possible - but it seems statistically improbable given the testing regimen that I know is used. If you do have one of these rare defective CPUs, then like the others, I encourage you to ask for an RMA and if you have issues doing this, then go ahead and email me - my email is in my Anandtech profile - and I'll see if I can poke someone from the inside.
Patrick Mahoney
Server Processor Division
Intel Corporation
* Definitely not a company spokesperson, merely an Intel engineer who posts on Anandtech *
