I have a maxtor 20gb ata-100 hard drive (primary) and a iomega zip 100 drive(slave) on the same cable, on the primary ide. The ide controller is ata-66.
does having the zip drive on the same cable degrade the performace of my Hard Drive at all?
No. The only situation in which you would see less than full speed is if you were using both devices at once (eg transferring from one drive to the other). Since IDE can only access one device at a time, half the time your HD wouldn't have access to the channel.
yes, just like having a CD-ROM drive on the same IDE controller as a HDD it will slow down data transfers. the HDD has to wait for the ZIP drive in order to begin transferring data.
