olds
- Mar 3, 2000
- 50,128
- 781
- 126
MacBaine is correct on the lights. The grooves you see cut into the road are indeed for the wires. Some lights are on timers. Moving back and forth can trigger the light if it's not on a timer. (Some detect the volume of traffic and if you move it thinks there are more cars.) Flashing your lights will do nothing. Weight used to be a factor, it isn't so much anymore but there are still older systems out there.
I work for the CA Dept of Trans, but I haven't worked highways for over 6 years.
Some more info.
Some more info.
