Does double-sided memory matter?
wraith3k
310
Just recently purchased two pairs of this memory (crucial pc3200 cl=3 512MB) except that it is single-sided. My question is does double-sided make a difference for an Athlon 64 (socket 939)? I just remember it having something to do with 3.2GBps versus 6.4.
Aleksandar
420
it matters on old pc133 or older on some mother boards they only read 128 mb as 64Mb
but in youre case no it dose not matter and maby you got Dual channel mixed up :)
3chordcharlie
9,859
The numbers you have are single vs. dual "channel", not single vs dual "sided". It does matter a little (someone did a comparison on this a few days ago, possibly AT, but I can't remember). But the differences aren't massive, and the ideal configuration depends on the particular system.
wraith3k
310
Which numbers are you referring to? Is the 6.4 I mentioned enabled when using dual-channel? I was talking about when you have memory chips on both sides of the DIMM, it is double-sided. I do know that dual-channel means two memory channels instead of one. :) But in several motherboard manuals, it is listed that you can have either single-sided or double-sided dimms, so I wanted to know what the difference was in performance terms.
PhlashFoto
3,893
17
Memory info
This might be of some help. What is the full Crucial part # of your memory? I've learned that just because a stick of RAM has chips on both sides doesnt automatically mean it is double-sided, but it can still be arranged in single-sided array..
wraith3k
310
Originally posted by: ELopes580
Memory info
CT6464Z40B
PhlashFoto
3,893
17
Memory info
CT6464Z40B
iWhats after that part number???
wraith3k
310
Memory info
CT6464Z40B
Nothing..here's the link though
wraith3k
310
there is no .8T or .16T after the part number???
Not that I'm aware of..of course the crucial site is down at the moment so I can't check either.
sunase
551
I noticed my Gigabyte 8KNXP only supports 6 sticks of memory if some of them are single sided (actually a limitation of the chipset iirc). Of course that's a P4 board, but it is a situation where SS vs. DS has mattered. ^^ I doubt SS vs. DS affects being able to run in dual channel at all. Afterall you can run dual channel with two sticks or four sticks and both setups have the same max bandwidth despite the former having fewer banks.
wraith3k
310
Originally posted by: nick1985
i really hope you didnt pay $92 a stick for that ram
I paid $85 per stick off newegg.
What would you have paid, or what type would you have considered otherwise?
nick1985
27,153
i would have gotten 2 of these and saved $26. plus, better timings to boot.
