Originally posted by: Wingznut
How could adding weight while working the muscles associated with jumping NOT help? (Unless you are saying that ankle weights aren't heavy enough.)Originally posted by: Syringer
:thumbsdown: to ankle weights. They're mainly used for aerobic activity to burn calories..they're not intended to improve hops.Originally posted by: antyler
I'm 6'2 and 145 pounds. I need to gain weight if anything. As for the jumping, I think that im going to try ankle weights and jumproping.Originally posted by: Wingznut
Pretty much the same as anything else... If you want to do something better, then do it more often.
If you want to jump higher, then jump to build up those particular muscles. Add weight, if jumping alone isn't a good enough workout.
Oh, and drop some weight if you need to.
Jumproping though is good :thumbsup:
Thats what i thought i heard like if you use 3 pound ankle weights will jump roping it would help. I mean naturally if afterwards you are still trying to jump, minus the ankle weights, you will leap higher? Seems logical anyways.
