ok, i have to admit a couple of things first: i'm from hawaii, born and lived here all my life (i'll admit to being at least 40 yrs old) of which at least 40 of those i have been actively and still do surf when conditions allow.
things to know and consider: SAFETY FIRST.
1. learn to swim first. then, learn to hold your breath under water while being tossed and rolled around and bumped off the reef by some waves without losing control of your board or maiming/drowning yourself doing it.
2. situational awareness is essential to your survival. yours, or those of your teacher/trainer. it's things that you don't see or are not aware of that will adversly affect you.
3. if you want to learn, surf where everybody else has the same skill level as you or people will ask you leave the area as you will be a dangerous threat to them.
4. loose boards in the surf always have the right of way, as well as any living creature bigger than you that calls the ocean home.
5. never, repeat: NEVER approach a wave or have the wave approach you broadside. if you're curious about that, try it once, close to shore with an ambulance waiting.
6. when beginning to surf, choose a board that will float you completely out of the water. your board is also your lifesaver. it also tends to keep you separated from things in the ocean that are curious about you in one way or another.
7. always have an experienced and trusted buddy with you in the water. he/she must have good eyesight, good hearing, good common sense and "surfing intuition".
8. when beginning, stick with one safe surf spot and get to know it well. surf conditions will vary greatly from that spot alone. don't go to an unknown spot unless you're with someone who knows the spot well, and has friends who surf there regularly. that way you avoid "trespassing" on what others might jealously consider "their turf".
9. learn to bail safely and cleanly. the most dangerous loose board in the water is your own.
10. slippery sun tan oil on your person will get you killed.
11. murky water at dusk or dawn will get you amputated.
12. the first wave of the set usually hides the bigger badder ones behind it.
13. if you see everyone else paddling in all at the same time and you're the last one out there, you're bait, and you're screwed and your buddy is either a genius or a coward.
14. ABOVE ALL, HAVE FUN!
