Originally posted by: KEV1N
Let's see, I shaved this morning at 8 and I'm already scruffy.
Am I shaving wrong?
Am I just too much man?
Has anybody tried the "beard slowing" shaving cream by Old Spice? (Or is it Adidas)
You think that is bad?Originally posted by: KEV1N
Am I shaving wrong?
Originally posted by: Gobadgrs
doesnt back against the grain give you razor burn and bumps? with me it does :|
Going against the grain does give razor burn, but it doesn't leave bumps. It takes off the bumps as well ^_^
Am I shaving wrong?
Originally posted by: FFMCobalt
Take some female hormone pills.
If you're seeing razor burn going against the grain, one of three things is happening: your razor isn't sharp enough, you're using the wrong kind of shaving cream (or not enough), or the hair is too long to be shaving against the grain.
If you see razor burn going against the grain, try using a sensative-skin shaving cream, shaving with the grain with a sharp razor, then re-applying a small amount of shaving cream after going with the grain before shaving against it.
won't that give you boobies ?
Oh, another thing. Use a lather brush. Not only does it look James-Bond suave doing it, but it helps stimulate the skin and extend the hairs outward. And of course, makes a nice lather.
- M4H
