ControlD
- Apr 25, 2005
- 5,440
- 44
- 91
I don't think it was the check valve, because the new pump uses the same check valve that was already on the pipe. Flapper style, I'm pretty sure.
Interesting. I might be mistaken then.
The older style check valves had a sort of ball mechanism that got pushed up when the pump ran. When the pump stopped the ball would drop back down making a thunk sound. I recently replaced mine (the ball mechanism broke loose and shot out the end of my sump discharge one day). The newer ones just have a rubber flapper mechanism that pretty much runs silently. I sort of liked the old style better.
That thunk is water hammer as the valve slams shut. You can get a silent valve. It drives me nuts as our pump runs all the time. I'm getting a battery backup and put a PTZ IP cam down in the basement so I can check on it if I need to.
I remember my dad waking me up in the middle of the night during a storm. (he worked 3rd shift)
The power was out and it was pouring outside.
The sump pump float switch was broken, so I had to manually engage it every ~30sec. for about 6 hours.
Once the hardware store opened, he got a new one.
...that was a long night and I remember my hand being frozen.
that's insane.
we have a pump and a battery back up plus a stand alone (old one i had).
My pump is 3-4 years old. this years it's been going a lot. when it turns off it makes a loud "clunk"
i don't think that is good..
edit: weird i been looking about the noise. just read that most likely its the check valve in the piping that is ruined. woooo!
