does a north bridge water block worth it ?
kikkler
30
i'm putting together a water cooling rig and i'm not sure about the NB block - should i include it or no ? what kind of advanteges shall i expect from a water cooled NB ?
Soulkeeper
6,740
156
depending on yur motherboard/chipset it could help you reach higher fsb speeds
if you increase the voltage to yur northbridge then it could get hot and extreme cooling could benefit it
if it's only a few bucks you might wanna give it a try
good luck
