Originally posted by: Muse
I made it to Harbor Freight today and bought
this charger. They call it a "float charger." On the box it says "Not A Trickle Charger." I wonder what they mean by that. It was 5 bucks.
The instruction leaflet inside says it won't overcharge a battery, that you can just set it and forget it, and it's for "flooded or gel-cell batteries." It's supposed to supply 13.2 volts.
The instructions also say to disconnect the battery before charging. I don't intend to do that and wonder if that will be a problem. Of course, I don't want to remove the battery from the car or even remove one of the cables from a battery terminal.
Would I be better off getting a "trickle charger?" What's the difference between a
float charger and a
trickle charger?
What I figure I'll do is run a power cord out to my cars and hook up my trickle charger that I got from Kragen to one of the batteries.
I'm not sure it's a trickle charger... it charges and when it senses that the battery is full, a red LED lights up, and presumably it stops supplying current. When it stops sensing that the battery is full (usually 30 seconds or so), the LED goes off and it starts charging the battery again. I always remove it when it gets to that point (when I notice it). I figure I'll run a second cord from one car to the other and put this "float charger" on the other battery and just plug and unplug the main cord from time to time rather than leave both batteries charging all the time. Maybe have them going a couple days a week, and monitor the voltage on the batteries until I have a feel for what percentage of the time these chargers have to be plugged in to keep the batteries fairly topped up. Of course, this assumes that both chargers do a similar job, which may or may not be the case. I could supply power to them separately in that case.
