document help
webcammie
545
Originally posted by: iamme
webcammie, you have no idea how quickly legions of horny, computer geeks will turn on you. either post some hot, sexy pics or change your title. you've been warned......*evil laugh*
but seriously, can you change it to a Word doc, edit it, and then change it back to a PDF? is this for a class?
It is in word doc. And no it is for my job. and if i dont get this figured out, i am not going home tonight. =(
Zanix
5,568
12
Originally posted by: Come to Meh
BAN
webcammie
545
Originally posted by: ChooChooChooseMe
Wouldnt this forum be better?
thank you. i am going over there right now. =)
I just want to put it on here because there are many people lounging around OT that's why
webcammie
545
Originally posted by: Taggart
no help until you provide a pic of yourself (assuming you are female)
that is your punishment for the tomfoolery
Do you know how???
iamme
21,058
Originally posted by: webcammie
I am working on a proposal (in MS WORD) and need to add an extra column in the document. However, it won't allowed me to do that because apparently the document is fixed and the only editing/writing I could do is on the gray box. I can't change any other words (like staff description, in-kind contributions, etc).
I am wondering how I could make a column after the "total" column? Anyone know?
can you move the sliders along the tab/ruler bar?
webcammie
545
nope. tried that and failed. i can't move anything!
iamme
21,058
maybe the fields are locked? try this:
How can I lock the fields in my document?
Keywords: Lock Fields Document
Posted May 17, 1996
After composing a series of documents using Insert - Field, such as the date field, Word automatically updates the field each time you open the document. However, if you want to lock that particular field to keep Word from updating it, you must do the following:
1. Highlight the field you want to lock
2. Press Ctrl+F11 or Ctrl+3
Locked fields look the same way as unlocked fields. The only way to tell them apart is to select the field and press F9 to update the field. If the field is locked, Word will not update it and your computer will beep to alert you.
To unlock a field:
1. Highlight the field you want to unlock
2. Press Ctrl+Shift+F11 or Ctrl+4
webcammie
545
Posted May 17, 1996
To unlock a field:
I can't even highlight any of the field because it is locked.
GeneValgene -- thank you thank you. i will send it to you right now!
Hyperblaze
10,027
Originally posted by: FoBoT
Originally posted by: Hyperblaze
why would you use MS Word to work with fields?
so, that would be more condusive to excel, right? or access
i dunno
yup. Any sort of field based work I would use a spreedsheet application such as MS Excel.
webcammie
545
Because proposal template they sent to us was word. But now they want us to include another column to one of the fields and that is why I am having a hard time because everything in the doc is lock except for the fill-out space.
iamme
21,058
*shrug*, i tried :(
Hyperblaze
10,027
sorry to hear. If you had had a choice...would you of done this in MS Word or MS Excel?
webcammie
545
Actually, with the whole documents...it is hard to do just excel because there are parts where you have to write essays. SO i would do it in word but i wont make it this hard to insert a column!
bootymac
9,597
I would redo the whole thing in Microsoft Excel because Word is retarded
And.. uh.. posting a teaser picture on a forum like this is probably the worst thing to do :p
