Do you use an electric or manual toothbrush
Do you use an electric or manual toothbrush?
  • Electric
    Votes: 30 60.0%
  • Manual
    Votes: 16 32.0%
  • Do not brush teeth
    Votes: 4 8.0%
  • Total voters
    50
Herr Kutz
2,545
242
I use this $39 Oral-B electric toothbrush:
https://www.amazon.com/gp/product/B003UKM9CO/
  • Night & day difference over a manual toothbrush
  • My dentist said I needed to go electric for my gums
  • It's like going to the dentist for a cleaning...every day (my teeth are so smooth!)
  • My dentist said that the super expensive ones were pretty much the same as the decent budget ones (~$40 Oral-B), so that's what I got
  • Refill heads (even knockoffs) are still stupid expensive (but they do last awhile)
Just set a slickdeal notification, just in case.
lxskllr
59,064
9,458
"Says British Dental Association"
I'll keep flossing.
Except it references America, and that America no longer recommends flossing. I grabbed the quick article, but the actual research papers should be easy to track down. Belief without proof is religion, and religion is bullshit.
Herr Kutz
2,545
242
I’m surprised electric is beating manual. I thought it would lean manual by at least 5 to 1.
ch33zw1z
39,038
19,730
I use an electric, recommended by my hygienist because of over brushing. It took some getting used to, but I like it.
sdifox
98,728
17,213
I use electric, floss aftwr every meal, use water pick every other day and mouthqash. Still have gum problems. At this point I think I'll get a industrial ultrasound cleaning basin and dunk my head in.
purbeast0
53,453
6,300
Got an electric one like 4 years ago and never looked back. It is a Philips Sonicare. It just cleans much better and also, the fact that it stays on for 2 minutes then cuts off, means I always brush my teeth for 2 minutes since I always go until it stops. Prior to that when I was doing manual, I wasn't brushing for close to 2 minutes.
My dentist could tell the difference the next time I went in for my 6 month cleaning and asked me if I switched to an electric. So she could tell from the condition of my teeth. She could also tell I brush with my right hand because one side was a bit cleaner than the other.
snoopy7548
8,211
5,271
I also like how it briefly pauses every 30 seconds so you can get an even brush throughout your whole mouth.
vi edit
62,484
8,344
Got an electric as a present. Won't go back to normal brushes any more. Teeth feel so much cleaner and I can get back into the way back corners of my molars a lot better with them.
Dental Care
Manual brushing makes you a bit more active in the morning if you don't have time for exercise in your busy mornings.
zinfamous
111,555
30,775
Men aren’t supposed to have vibrators?
No problem with that, as long as they aren't "disposable" vibrators to be tossed out simply because a shitty battery has died.
None of this is actually disposable. Generating more waste--and far, far, far worse types of waste--than previous generations is going in the absolute opposite direction of where we are required to be going as a species that is interested in its own survival.
31,958
We another name for "disposable". Maybe high waste or limited use. Perhaps another thread.
paperfist
6,539
286
www.the-teh.com
Save your mouth and save the planet. You’re a good man.
DietDrThunder
2,262
326
Do I feel bad about tossing them out? I once did. We found out from the city that the market for all recycled products has tanked. Other than toxic chemicals like paint, etc., which go to a different collection station, and even though we have to separate our "recyclables" from garbage, all recycling and garbage is being directed by the city to the local landfills, and the city's recycling centers have pretty much been shut down. The city is hopeful that by the Fall, the recycling centers will be at 50% capacity again.
blackangst1
22,902
2,359
Same!
