Originally posted by: OIKOS
...... CRT?? is that a monitor or......?![]()
Originally posted by: Harvey
Only if you don't need the screwdriver, anymore. With 25,000 or more volts running around in there, you could zap off the tip of the screwdriver. If you're lucky you won't get a chunk of molton steel in the face.Originally posted by: Howard
Use a screwdriver with a long rod, wrap the rod with electrical tape, and you should be ok.
I've been inside monitors and TV sets. It helps to know what you're doing.
okay, you have officially scared me. how can that energy instantly melt the metal in that screwdriver?
lol, it wouldn't.... he was being a bit dramatic. It may be 25,000 volts, but that doesen't mean sh!t if it's at 0.5 amps(which is a lot @ 25kV)Originally posted by: Linux23
It *IS* possible to melt tools though, with enough amperage. Try dropping a wrench across a car battery sometime. :Q(If you want a darwin, that is).
Originally posted by: CTho9305
I'd do it, but my monitor case is basically one piece in the back, so removing it means no stand, and I"m not exactly comfortable running it like that.
Originally posted by: Goosemaster
Pics?
of the knob i mean....my 19'' Sony 400PS is blurry as hell
the reason i believe him is because my father told me that his screwdriver slipped inside of the CRT monitor, and his screwdriver was all shot to hell.
oh, and i heard that if you touch both the neg and pos terminals of car battery with your hand, you will get a serious surprise.
LOL........Originally posted by: Linux23
How does an ignition coil turn 12v into 40kV again?Originally posted by: Walleye
you need some serious resistance, and a jump, to get the voltage required do a shock.
that's how ignition coils turn 12 volts into 40,000. go ahead, put your hands on the terminals of a battery. i guarantee you wont feel anything. the electricity will be flowing through you, but you wont feel it. so dont worry about it.
Originally posted by: Eli. Have you ever been "seriously surprised" by a 9v?![]()
Originally posted by: SagaLore
I wonder why they don't just put those focus screws on the outside of the monitor... although I do understand why you can't put it into the digital menu because of the physical aspect of it.
