Do you have eye floaters?
LordSnailz
4,821
29 and I get them ... doctor said it's mostly likely because I have hints of retinal detachment :(
RKS
I think most of these 'floaters' occur in-utero; you probably don't notice them until later.
floaters are just remnants of an artery and vein that connected to the lense in your eye when you were in utero
cjmtfd102401
502
Floaters are common. However if it looks like someone has pulled a window shade down, it looks like there is a hair net over you eye, or have bright flashes of light get to an ophthalmologist ASAP.
Pacfanweb
13,155
59
I"ve had those since I can remember as a child. They never are big enough to block out anything, but if I concentrate I can see them most any time.
alkemyst
83,769
19
I gave a few girls floaters in their eyes...some haven't controlled things well can gave me a couple.
At 22 you should be giving and possibilly recieving more than older folks.
rh71
52,844
1,049
I get something similar right before migraine headaches but in a sense it's good because it's a symptom to the migraines and I know when to take my Zomig. The "floaters" is more like a blind spot right in the middle of my field of vision. I also feel nausea... actually just thinking about all this is giving me nausea... bad memories. To much MSG in foods has been my trigger.
Locut0s
22,205
43
Got them here, 25 yrs old. Had them as long as I can remember. Wear glasses had many eye exams nothing to worry about unless you have other problems associated with them. I don't notice them unless I concentrate on a blank uniformly coloured space like the blue sky or a blank white screen.
alkemyst
83,769
19
they are like trinitron scan lines. If you don't pay attention to them you don't know they are there.
Migraines trigger something different than what floaters look like...i think we see our eye circulatory system go haywire.
I don't take anything for mine, they are rare though...one trigger is heavy squats when I begin lifting after a break. I know in about 30mins from the first signs, I will be mostly blind for about 1 hour. I also get a slight numbing of my upper lip.
The headache I just deal with, it lingers about 2-3 days.
BoomerD
65,898
14,296
I knew I had lost the battle with my blood pressure when I could start to "see" the veins in my eyeballs as my heart beat...my doctor agreed with me...said it was a sign...I started taking the hated pills that day and don't "see" the veins any more.
CycloWizard
12,348
Floaters are just cells falling through the gel that is your vitreous humor. The vitreous liquefies with age, so the cells move around more and become more noticeable. The size of floaters depends on their location in the eye, since they will block more incident light if they're closer to the retina where the rays are more tightly focused. They're fairly normal, but if you notice a dramatic, relatively sudden increase, it can be an early sign of retinal detachment and you should probably get it checked out. /late Saturday night ophthalmology rant
alkemyst
83,769
19
hope that's not caused by getting riled up on ATOT.
gorcorps
aka Brandon
Jul 18, 2004
30,739
454
Yes... noticed them a few years ago when I started college. I have one really noticeable one in my right eye and a very light one in the left.
manlymatt83
10,051
44
Originally posted by: thirtythree
I've noticed recently that I have a lot of eye floaters. I typically only notice if it's bright out. If I move my eyes from left to right rapidly I can see them floating around inside my eye. It sounds like they're pretty common, especially in older people, but I'm only 22, so I wanted to do a little survey. How old are you, and do you have any or a lot of eye floaters?
EDIT: And if you don't want to click on the article, eye floaters are basically just specks or strings that float around in the fluid of your eye and can be seen when looking at bright objects such as a blue sky.
Yep, since 23!
manlymatt83
10,051
44
and how long ago was that? what does your bp usually run?
clamum
26,252
403
I see them sometimes if it's bright. That article states they're more common for people with nearsightedness, which I have.
