squirrel dog
- Oct 10, 1999
- 5,564
- 48
- 91
How does the gas usage compare to before you converted? Does your furnace run less? Was is expensive to install and did you do it yourself?
gas usage is more,but not by much($20) I had the pipe already in place inside my wood burning fireplace,so I went to a gas log shop here local,picked out a nice looking pile of ceramic logs,went home and connected the stainless line from the gas logs to the pipe I had in place.Took about 30 min.The logs cost I'm thinking about @250~300 ish(ten years ago).Use it all the time when it gets really cold,fireplace was built with a fan,so it puts out the heat,I never leave it on when we go to sleep.Also have several co monitors around the house,as my furnace and hot water heater are nat gas also.I went from wood to gas for the convenience and I tired of the wood smoked smell that would permeate the house.Yes the furnance runs less,but not by much,maybe 2~3 degrees.
