Do you conserve fresh water by not flushing after urination?
Hell no I flush after every time. Your pee will stain your toilet if you let it sit in there. I could care less about conserving water.
Why the hell would I conserve water?
1. The cats routinely drink from the toilet
2. Conserving water is a waste of time unless you live in an area where the supply of water < the demand for water.
The water table holds a finite amount of water. It's constantly replenished. Around here, use is less than the rate it's replenished.
How much less could you care? 40% less? 50% less? It's important to set achievable goals for yourself & attempt to hit those goals. Maybe we could all pitch in and try to help.
Instead of pumping your A/C condensate on the ground bunker it and use it to flush your bowl if you're that concerned about water usage. 😉
I live in a desert and I flush my toilet every time its used. The water gets flushed into the sewer system where it ends up in water treatment facilities.
Water flushed down the toilet or urinal doesn't simply disappear, never to be used again.
Hell no I flush when I pee.
I like to flush the toilet at all hours of the day at random for no reason, too, just to piss off conservatives. 😉
You mean liberals and environmentalists? 😉
I think you have bigger problems than conserving water. :laugh:
