Do me a favor guys. Go into your cable modem website and post your power levels.
pontifex
43,804
46
Originally posted by: Vortex22
Originally posted by: chuckywang
Go to 192.168.100.1 and browse around there.
Blank page for me. Probably because I'm behind a router.
its going to be different for different models. i think my dsl modem is 192.168.0.1
Dulanic
9,969
592
Downstream Value
Frequency 693000000 Hz Locked
Signal to Noise Ratio 37 dB
Power Level 9 dBmV
The Downstream Power Level reading is a snapshot taken at the time this page was requested. Please Reload/Refresh this Page for a new reading
Upstream Value
Channel ID 3
Frequency 35600000 Hz Ranged
Power Level 55 dBmV
My power levels are always bad, I have to have a cable line amp just to not get dropped all the time.
Mo0o
24,227
Power Level -5 dBmV The Downstream Power Level reading is a snapshot taken at the time this page was requested. Please Reload/Refresh this Page for a new reading
slackwarelinux
540
Forward Path:
Signal Acquired at 495.000 MHz
SNR: 37.8 dB
Received Signal Strength: -4.0 dBmV
Bit Error Rate: 0.000 %
Modulation: 256 QAM
Return Path:
Connection: Acquired
Frequency: 13.6 MHz
Power Level: 47.0 dBmV
Channel ID: 10
Modulation: QPSK
Dean
2,757
Signal to Noise Ratio 39 dB
Power Level (downstream) 2 dBmV
Power Level (upstream) 37 dBmV
Squisher
21,204
66
Downstream Value
Frequency 597000000 Hz Locked
Signal to Noise Ratio 38 dB
Power Level 2 dBmV
Upstream Value
Channel ID 4
Frequency 26992000 Hz Ranged
Power Level 44 dBmV
rambow
Banned
Dec 6, 2005
188
Downstream
Freq/Power: 591.000 MHz -9 dBmV
Signal to Noise Ratio: 35 dB
Modulation: QAM256
Upstream
Freq/Power: 33.008 MHz 54 dBmV
Channel Type: DOCSIS 1.x (TDMA)
Symbol Rate: 2560 kSym/sec
Modulation: QAM16
Eos
3,463
17
Downstream Lock : Locked
Downstream Frequency : 723000000 Hz
Downstream Modulation: QAM256
Downstream Interleave Depth: 32
Downstream Receive Power Level: 11.2 dBmV
Downstream SNR: 33.0 dB
Upstream Channel ID: 3
Upstream Transmit Power Level: 49.3 dBmV
Upstream Symbol Rate: 2560 Ksym/sec
Upstream Frequency: 31296000 Hz
Upstream Mini-Slot Size : 2
Upstream Burst
request(1) initialRanging(3) periodicRanging(4) shortData(5) longData(6)
Modulation Type QPSK QPSK 16QAM 16QAM 16QAM
Differential Encoding Off Off Off Off Off
Preamble Length 32 64 64 128 128
Preamble Value Offset 0 64 576 640 640
FEC Error Correction (T) 0 5 5 4 9
FEC Codeword Information Bytes (k) 16 34 34 76 232
Scrambler Seed 338 338 338 338 338
Maximum Burst Size 0 0 0 7 137
Guard Time Size 22 48 48 22 22
Last Codeword Length Fixed Fixed Fixed Short Short
Scrambler on/off On On On On On
Quasmo
9,630
Modulation 256QAM
Channel ID 36
Symbol Rate 5360.537 Ksym/sec
Downstream Power 11.2 dBmV
SNR 37.8 dB
Upstream Channel
Lock Status Operational
Modulation 16QAM
Channel ID 5
Symbol Rate 2560 Ksym/sec
Upstream Power 40.5 dBmV
Oceandevi
3,085
Frequency 615000000 Hz
Signal to Noise Ratio 35 dB
Power Level 5 dBmV
Channel ID 1
Frequency 19500000 Hz
Ranging Service ID 857
Symbol Rate 2.560 Msym/s
Power Level 45 dBmV
Amused
57,479
19,988
Downstream
Power Level -7 dBmV
Upstream
Frequency 32000000 Hz Ranged
Power Level 44 dBmV
-7? Is that bad?
fatpat268
5,853
Downstream Value
Frequency 687000000 Hz
Signal To Noise Ratio 36.5 dB
Power Level 0.6 dBmV
Upstream Value
Channel ID 1
Power 50.0 dBmV
RGN
6,623
SNR: 34.0 dB Frequency: 20.8 MHz
Received Signal Strength: -3.1 dBmV Power Level: 40.3 dBmV
Micro-Reflections: 42 dBc Channel ID: 11
Modulation: 256 QAM
OVerLoRDI
5,490
4
38 SNR
DS = 0 dBmV
US = 49 dBmV
Really weird... i think it might be busted saying 0 for DS.
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
192.168.100.1 has a bunch of porn and a surfboard in the corner. That site is not work safe! :|
dartworth
15,200
10
Status Comment
Acquire Downstream Channel 765000000 Hz Locked
Connectivity State Operational Operational
Boot State OK Operational
Security Enabled BPI+
Downstream Channel
Modulation 256QAM
Channel ID 209
Downstream Power -1.0 dBmV
SNR 34.4 dB
Upstream Channel
Modulation 16QAM
Channel ID 2
Upstream Power 38.0 dBmV
Shawn
32,236
53
Startup Procedure
Status Comment
Acquire Downstream Channel 627000000 Hz Locked
Downstream Channel
Lock Status Locked
Modulation 256QAM
Channel ID 0
Symbol Rate 536.0537 Ksym/sec
Downstream Power 0.1 dBmV
SNR 34.8 dB
Upstream Channel
Lock Status Locked
Modulation 16QAM
Channel ID 3
Upstream Power 44.0 dBmV
