Do me a favor guys. Go into your cable modem website and post your power levels.
Scouzer
10,358
Downstream Rate: 5984 kbps
Upstream Rate: 640 kbps
Channel: Interleaved
Current Noise Margin: 13.0 dB (Downstream), 20.0 dB (Upstream)
Current Attenuation: 13.5 dB (Downstream), 12.0 dB (Upstream)
Current Output Power: 7.3 dBm (Downstream), 9.9 dBm (Upstream)
...but thats my DSL:D
PurdueRy
13,837
4
Downstream
Freq/Power: 621.000 MHz 2 dBmV
Signal to Noise Ratio: 36 dB
Modulation: QAM256
Upstream
Freq/Power: 31.500 MHz 43 dBmV
Channel Type: DOCSIS 1.x (TDMA)
Symbol Rate: 2560 kSym/sec
Modulation: QAM16
SoulAssassin
6,135
Forward Path: Return Path:
Signal Acquired at 723.000 MHz Connection: Acquired
SNR: 34.0 dB Frequency: 31.0 MHz
Received Signal Strength: -6.0 dBmV Power Level: 43.8 dBmV
Micro-Reflections: 35 dBc Channel ID: 7
Modulation: 256 QAM Modulation: QPSK
mobobuff
11,099
Frequency....... 561000000 Hz
Signal to Noise Ratio....... 35 dB
QAM....... QAM256
Network Access Control Object........ ON
Power Level........ 0 dBmV The Downstream Power Level reading is a snapshot taken at the time this page was requested. Please Reload/Refresh this Page for a new reading
Channel ID: 3
Frequency: 24750000 Hz
Ranging Service ID: 7917
Symbol Rate: 2.560 Msym/s
Power Level: 45 dBmV
wazzledoozle
1,814
Mine doesnt have any of that info, there is a basic panel about the modem's model # and then a login form. (Dont know pass?)
I have comcast... perhaps thats why.
Anubis
78,712
427
tbqhwy.com
Downstream Value
Frequency 699000000 Hz Locked
Signal to Noise Ratio 36 dB
Power Level 2 dBmV The Downstream Power Level reading is a snapshot taken at the time this page was requested. Please Reload/Refresh this Page for a new reading
Upstream Value
Channel ID 1
Frequency 31008000 Hz Ranged
Power Level 44 dBmV
mwmorph
8,877
I get nothing because I cant log in. I have no idea what the password or login could be
rocadelpunk
5,589
Downstream Value
Frequency 651000000 Hz Locked
Upstream Value
Channel ID 3
Frequency 32096000 Hz Ranged
Power Level 37 dBmV
Dec 10, 2005
28,026
12,615
Downstream:
Frequency 603000000 Hz Locked
Signal to Noise Ratio 35 dB
Power Level 1 dBmV
Upstream:
Channel ID 1
Frequency 27998876 Hz Ranged
Power Level 46 dBmV
deadlyapp
6,658
737
Forward:
Signal aquired at 711.000MHZ
SNR: 37 dB
Recieved signal Strength 9.4 dBmV
Micro Reflections: 38 dBc
Modulation: 256 QAM
Return:
Frequency: 23.0 MHz
Power Level: 46.0 dBmV
Channel ID 8
Modulation: 16 QAM
jfall
5,975
Frequency 561000000 Hz Locked
Signal to Noise Ratio 38 dB
Power Level -1 dBmV
Channel ID 11
Frequency 21968000 Hz Ranged
Power Level 39 dBmV
microAmp
5,988
110
Ditto but with Road Runner, basic Admin passwords didn't work.
