Do I need a new sound card?
dbuttcheek69
231
i have my rig hooked up to my home theater reciever. im using ASUS onboard audio, and recently I've been getting a lot of static.
i have all gold connections, so i know thats not the problem. speakers are ok, wires are all ok...
could it be that i should get a sound card? are there any benefits over onboard?
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Does it just give you static when the comptuer is the source?
If so, an AV-710 with digital optical connection should give you a very nice interference free connection.
Do you have it set up now with 1/8" to RCA adapters to a 6 channel direct input now?
dbuttcheek69
231
no im just using a headphone adapter right now plugged into the green speaker port with RCA connectors at the other end going into my reciever
thanks alot man its people like you who really make anandtech a great place to post and get help
DrCrap
238
I don't know if this helps, but I used to have issues with my o/b sound-card after changing video-card, it turned out I had some driver conflicts.
If you recently installed somthing new, look for conflicting drivers.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Do you still get static if you hook something else up to it?
(Like a portable cd player attached to the input instead of the computer?)
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Do you have all the stuff muted that you're not using? (line-in etc.)
EDIT: on the sound card options I mean
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
In the windows volume control, there should be options to mute line-in and other things. If your line-in isn't muted, it may be causing statid.
(go to control panel and sounds and then advanced)
