do fans actually lower temperature? (i mean the in-door portable variety)
pennylane
6,077
do they really lower temperature?
or do they just provide a "wind chill" so the perceived temperature is lower?
also... would it be safe to plug in a portable fan in the same power supply i'm plugging in my computer/monitor/printer?
Jan 31, 2002
40,819
Depends what the temperature of the air you're moving is. :p
I wouldn't plug that fan in the same UPS/splitter myself, but it won't really harm it I don't think.
- M4H
Anubis
78,712
427
tbqhwy.com
its just "wind chill"
and yes that is safe. you shodul see what i got pluged into things
the AC is on teh same strip as my comp
rgwalt
7,393
Moving air feels colder as it has a better heat transfer coefficient and it carries moisture away for evaporative cooling. So, fans don't reduce the temperature. In fact, a fan blowing in a closed room will actually heat the room up.
Boom.
Ryan
atom
4,722
I position my fan next to the window so it draws air from the outside, so it does make the room cooler. Obviously it doesn't cool if the ouside is just as hot.
pennylane
6,077
Good idea.
Ultima
2,893
Where did you get the idea that they lower temperature? They just move air. If the air they're moving is cooler than the object they're cooling, then yes it will cool that object down. Tthe more air moving over something, the faster its temperature is changed.
