Do any of you tinkering packrats happen to have a 12 - 60RPM geared motor laying around?
Eli
Super Moderator | Elite Member
8
Anything in that RPM range is fine. DC 12 or 24v, or A/C is fine.
I'd be happy to take it off your hands. :)
Or I'm going to have to buy something like this, but I don't want to spend that much.
TIA. :)
Edit: Fsck.
Well, I lost the auction, lol.. So I'm still looking.
This is what I was going to buy.
Nothing particularly special about them, except the nice 3-screw adapter on the shaft! It would've been perfect. It's really my only hangup. I could use any old motor, but most of them come with no usable shaft adapter.
Those things look almost exactly like the typical power window motor, except they are 24VDC and instead of a sprocket on the shaft, they have the 3-screw adapter thingie.
If anyone has seen a power window motor with a similar attachment on the shaft, I'd really like to know the make and model of the car.
I've been trying to make out the information on the tag visable in the pic, but I haven't been able to so far. Does anyone recognize that logo?
All I know about them is they were made in germany... lol
Eli
8
Originally posted by: AgaBoogaBoo
out of curiosity, what will you use it for?
I need to turn something at a slow speed. ;)
Think rock tumbler.
Eli
8
bump for the night folks...
Go look in your junk drawers people. :p
Analog
12,755
TIA. :)
Eli,
Here is a 40 rpm for $3.99, but its 120vac: http://www.surpluscenter.com/i...9&item=5-1335&catname=
Here is a 15 rpm for $4.95, 24VDC:
http://www.surpluscenter.com/i...9&item=5-1451&catname=
Here is all of them, sort by price!
http://www.surpluscenter.com/s...r&UID=2005011804050249
BTW, I order stuff from these guys all the time, they're great. I built an aerator for my pond from basic parts, and I saved big $$. If you're looking for motors, compressors, vacuum pumps, or other stuff along those lines, these are the guys.
HTH :)
Eli
8
TIA. :)
Eli,
HTH :)
Awesome, thanks.
I've found something on eBay that should be nice. 65RPM @ 24VDC .. going to run them at 12VDC, hopefully that will give me about 30RPM.
And the motors come with shaft adapters, that's probably the most alluring aspect.. lol.
Eli
8
Fsck.
Those things look almost exactly like the typical power window motor, except they are 24VDC and instead of a sprocket on the shaft, they have the 3-screw adapter.
Ornery
17
My '88 E-150 has nearly that exact motor in it (actually a bit larger). I can't imagine it being used for constant duty though. The reason I know is, I had to replace the brushes in mine this summer.
Insane3D
19,446
Yeah, it looks exactly like the window motors in my '92 GT.
Eli
8
I can use any old low RPM motor really, the issue is the shaft coupling.
I guess I could get a motor and go from there ....
RossMAN
Grand Nagus
Feb 24, 2000
78,974
417
Originally posted by: His Lord Uberdude
Originally posted by: RossMAN
WTF is a rock tumbler?
<--- mechanics challenged.
I'll use small words; It's how they make rocks shiny.
Why would someone want to do that?
and your small words match your small penis just perfect :thumbsup:
Phoenix86
14,644
10
Come on, he wants his rocks polished. What more do you need to know. ;)
Eli
8
LMAO! :D
Ok, instead of rock tumbler.. think rotisserie.
But yeah, a rock tumbler is the nitty gritty(no pun intended.....lol) way to polish rocks to a mirror shine. Generally, you polish pretty rocks like agates and such. :p
What the fsck would you call the adapter that is on the output shaft of those motors I linked to on eBay?
I can't find anything like that anywhere. Shaft flange? Shaft adapter flange?
:confused:
Eli
8
Think rock tumbler.
How did the crop turn out?
:confused:
I rarely crop my pictures.
Only the second picture shows that "hub". My window motors are lacking that.
Yeah. None I can find have anything like that. It wouldn't matter if I knew how the gear was attached to the shaft.. If the shaft is threaded, inside or outside.. that would be acceptable.
Those aren't power window motors, though... unless there's a car that uses a 24V system. I don't know what they're for Hmmm.
I've found This though.I think it will work.
