Do all rear projection TVs have a fresnel lens? Update: Evil laugh!!!!
SSSnail
17,458
83
86
Maybe I should revive some of my childhood mischief and awaken... wait, that child in me never went anywhere...
Ooooh... candies!!!
14,042
Fun stuff. See if you can build a boiler and generate electricity with that. :D You would want to avoid complete focus though or you'd just melt the rad. :p
phucheneh
7,306
OP, you have access to a quality IR thermometer, by chance? I'm curious how hot that's actually getting.
Also, the problem with trying to generate electricity, or otherwise do work, aside from the general absurdity of the entire endeavor, would be moving the lens constantly. Perhaps you could design some kind of clockwork mechanism that you wind up in the morning, and the lens slowly moves over the course of the day (...in before the lens swings the wrong way and you light the moon on fire*).
(*this is sarcasm, if someone tries to 'educate' me on how far away the moon is and/or how lens focusing works I will slap them)
BTW, if anyone is curious: melting point of nickel is 2651* F, copper is 1984* F.
...holy fuckballs.
PottedMeat
12,363
475
i bet it wouldn't be too hard to adapt one of those solar panel trackers for this
i see projection tvs out for cheap/for free all the time but i'm just too lazy to get it home
35,363
I'm traveling for work now so no new videos/pics for a while. My wife melted down silver scrap yesterday. The borax flux is so bright under the lens that it is hard to look at even while wearing welding goggles. We also made smores.
35,363
Melting asbestos tile
I checked the glass under a microsscope and confirmed that the asbestos fibers themselves melted. The asphalt binder vaporized and burned off.
phucheneh
7,306
Here's a thought...what about the small lens in the back of the TV that focuses the light from the bulb? Going with the whole TV-parts-in-reverse thing, could you put it under your fresnel lens and focus the light into a proper goddamned moon-laser? Or are you already past the melting point of the glass?
oynaz
2,449
The difference between knowing and understanding:
I knew there was a fresnel lens in projector TVs.
I didn't understand it until you turned one of them into a solar powered death ray.
edro
24,326
68
Can you look at the beam with your naked eye?
I would think the reflection off a nickel (or other semi-specular surface) would damage your eye.
Did you need sunglasses or welding glass?
35,363
Welding goggles are essential. I will need to buy a welding curtain if I decide to show it off in person. When cooking marshmallows, the reflection off the white surface is brighter than the sun.
silverpig
27,703
12
More videos:
Melting a nickel 1 (75% copper 25% nickel)
Melting a nickel 2
The camera is fine. One feature of solar concentrators that makes them easy to use but also dangerous is that outside of the focus spot there is very little heat. Stuff in the focus point can be burning or melting while the camera can be inches from the focus without harm.
It's not the heat... it's that the light is so bright you are saturating some of the pixels in the sensor and current is leaking through to other pixels. If you do this too much you can damage the sensor.
BladeVenom
13,365
16
Would it? Or could you direct the beam somewhere else? Inquiring minds want to know...
A mirror doesn't reflect all the light, so it would still get hot. I think a common plastic mirror would still absorb enough heat to start to melt and burn the plastic, and then it's reflectivity would be lost, and burn up like anything else. A high quality silver glass mirror would stand a better chance.
Pulsar
5,224
306
And in the mean time, if you were close, you could burn our your eyes! Bonus!
mizzou
9,734
54
hey, could you use this to smelt the gold flakes and silver from PC equipment?
35,363
So I made popcorn today. Only about half the kernels burned before they could pop. Not great but not horrible for a first try. Then I found this. I have been outclassed in every possible way.
