Originally posted by: KnightBreed
			Originally posted by: DragonMasterAlex
			Originally posted by: Newfie
terminator 3: extreme edition i do believe
It's got a 720p version.
1080p *isn't* officially part of the HDTV specification, at least not yet. Even if it were, most movies would probably ship in 720p on BluRay or HD-DVD media, probably encoded h.264.
Where did you get this bogus information from? The ATSC standard for digital broadcasting has specs for all sorts of input signals I bet you know nothing about: 720i50, 720i60, 720p24, 720p25, 720p30, 720p50, 720p60 , 1080i50, 1080i60, 1080p24, 1080p25, 1080p30 (
see page 33 - or see
here for all links)
The resolution and encoding format is going to vary from studio to studio. The most likely scenario is that most movies come in 1980x1080x24psf - the use of mpeg2, mpeg4, or vc-1 will depend on the studio.
			While all true HDTV's support 720p and 1080i, NONE supports a 1080p input (which is fine, since there aren't any). Some of the newer HDTV's claim to *upsample* to 1080p, but personally, I'm skeptical.
Jason
Skeptical about what exactly? If you feed a native 1920x1080 display a source of 480p, it
has to upsample the video to fill the panel. Otherwise you'll get a lot of unused screen space.
