Is there anybody else running this combo upgraded to the latest firmware(2.03g) on DI-614+ and the latest driver(2.2) on DWL-650+?
I'm having problem after that. The DWL-650+ is plugged into a Dell Inspiron running WinXP. It has a rather funny symptom. When system boots up, it gets a wireless connection, then after a couple of seconds, it drops, after another second, it picks up again, only to drop it again couple of seconds later, and so on. At this point, if I put the machine to hybernation, then wake it up, everything starts working! the connection isn't dropped any more.
On top of that, I found this happens only when I have WEP enabled. If I use the factory default settings, i.e., no WEP, it works fine.
Anybody else seen this?
