Originally posted by: Templeton
I'm actually in the middle of building one of these, so I'll try to help. If you've never done any pc board soldering, it's really not that tough as long as you are careful of a few things. Don't use too much solder, you'll quickly find blobs of solder joining together and creating quite the mess. If you do need to clean up excess solder, or have mispositioned a component, have a solder sucker and/or desoldering braid handy. Make sure you have the right tools for the job, nothing sucks more then not being able to finish a project cause your drill is 1000 miles away.
This site should be handy, it includes part numbers for all the necessary components from several suppliers, and a pretty decent walk through on assembling the thing. If you're cheap like me, you can request a sample op-amp from ti. Extra things can quickly start adding on to the cost of the amp, a potentiometer for volume control is nice, but do you really need it if the device it's hooked up to already has volume control? An external power supply can be nice if you're planning on using it with you're desktop pc, but a 9volt battery should last awhile anyway. I say that you build it with the bare amount needed first, then if you find that you would like another feature, implement it later on. Hope this helps.
