This plus the fact that they're often rear-ported make HT use problematic.What are you going to be powering them with? 2 driver "DIY" setups have a nack for being pretty hard to drive....84-86db of efficieny.
I have a pair of DIY zaph SR-71.
also a DIY rythmik audio 12" sub.
fantastic.
If you're willing to add each item to your shopping cart individually, the Overnight Sensations MTM look pretty nice and should sound okay being driven by a 15W T-amp as long as you don't expect insane sound levels.
http://sites.google.com/site/undefinition/overnightsensationmtm
The 2 way version is a little less expensive, but won't be as loud and will probably need a subwoofer to fill out the lows.
Looks like a cool build but I'd replace the tweeters with these...
Dayton DC28F-8 1-1/8" Silk Dome Tweeter
^ this 110%. May also be worth considering the relative performance of the two drivers...the $8 ND20FA has much lower distortion and slightly better frequency response than the DC28F. http://www.zaphaudio.com/tweetermishmash/compare.htmlit's not as simple as just replacing the tweeter, the crossover was designed for the tweeter specified. If you go and change that you'll have to design your own crossover taking into account the impedance and frequency response of each driver individually as well as combined, it's not as simple as just plopping a different driver in the cabinet. The speakers mentioned are designed by very competent people, I wouldn't try and tweak or tune unless you've got some experience in doing so. For the inexperienced the results could be disappointing to say the least.
Firstly "WOW!!! NO SHIT???"
But to all that didn't assume that "DIY" might mean tweaking your crossover to 2.5kHz or some where in that range... Sorry I failed to mention that... As far as changing the box design I doubt that the Box is going to make a big difference since tweeters don't move much air at all. Mostly box design is for the woofer not the tweeter.
Interconnects and wiring??? Seriously??? There are about a hundred things that will have a more profound affect on sound than interconnects and wiring.
someone explain to me what these graphs mean. is it smoother the better? bigger range the better? Im assuming thats the case since the most expensive tweeters seems to have a much smoother and wide-ranging curve than the cheapest
ScanSpeak 7000 - $398
Hi-Vi T20-4 - $5
Much lower distortion than the DC28F; the distortion I was speaking of is inherent to the particular driver's design. The link I posted allows direct comparisons between many tweeters, including the ND20FA & DC28F, for measured CSD, freq. response and distortion profiles.Much lower distortion then what?
If you would have read the post the dude wants to use a CLEAN 15 watt T-amp. Not a garbage trash can amp. Clean amps you don't need to turn up anyway. So, so much for the distortion claim unless the specs are wrong @ 55 watts... As for frequency, well... If you like the tin sound then go for it. I like the driver I think it pairs up nicely with a T-amp.
But I don't think it's such a huge stretch that an $8 tweeter can outperform a $13 one. Although if 'tin sound' means more to you than lower distortion, use whatever you want.Bottom line is this..... It's a CHEAP ass tweeter to begin with you can't expect million dollar results with a cheap tweeter tho. With a little tweaking you can get damn good results.
🙄As long as you use decent internal wiring and interconnects ... It's gonna sound pretty nice.
Good Luck.
