- May 16, 2008
- 3,180
- 0
- 0
DIY Quick Guide:
Thermal paste / Thermal Inteface Material (TIM) Replacement in 15 minutes.
Check out Intel's guide for basic info on replacing TIM.
Here is Intel's guide to applying TIM on CPUs.
http://www.intel.com/support/processors/sb/CS-030329.htm
Disclaimer: Some manufacturers will void your warranty, while some will allow you to change the TIM. Verify that if you care. This guide is merely the way I have chosen to do things, there are varying opinions.
1. Pull of the (four) screws that actually hold the cooler on.
* Check out the cooler cables, some may need to be removed as you take the cooler off.
* Check for possible screws from the cooler to the endplate where the display connectors are.
2. Separate the Cooler from the PCB slowly, ensuring everything is disconnected.
* In this case I was able to keep the cooler wire connected the whole time since there was so much slack. Usually you need to disconnect it since there will only be an inch or so of slack. Be careful for this.
* Note the very poor TIM placement. It was completely dried and crusty as well as uneven.
3. Clean off the old TIM Thermal paste.
I simply used paper towels and scraped at it with my fingernails a bit until it broke loose. The mating surfaces have to be extremely clean so if you use paper products ensure you have cleaned off any remains.
Rubbing alcohol is commonly used, be careful if you go that route.
4. Apply new TIM.
The GPU doesn't have room to tighten and once the screws bottom out you can't go tighter. The pictures make it look like there's a lot of
TIM, however when spread out it's not very thick.
GPU vs. CPU
* There is debate about it does require more than a normal CPU. It is more then I would put on a CPU since a CPU needs a thin layer which is basically just barely adequate to "cover" the cpu.
5. Spread out the TIM (or put it in a dot / line / etc. in the center)
* I chose to use a plastic bag and smear it around and dab it gently until it was pretty uniform. The dots are not nearly the size they appear to be. There are many opinions on the proper way to put TIM on, read up and find your own way to do it (whether it's the dot / line / spread pattern).
6. Put it back together
Gently line up the coolers screw holes with the PCB while holding it upside down and gently start the screws on opposite corners.
Screw in each screw about 1/2 turn until they all bottom out. Don't twist hard or they will strip very easily and most manufacturers will
call it "physical" damage and won't RMA the video card.
7. Results.
Pretty dramatic, almost unbelievable with such a minor change. (I did de-dust it as well simultaneously, however it wasn't very dirty)
I didn't take any other screenshots but I was seeing the lower 90's which prompted a change.
Before: 87C
After: 78.5C
Note the Paste hasn't cured yet and could change a bit. Also with long running times the temperatures will go up (as would the before temps though too).
* Footnote
Do note that I wouldn't count on such dramatic results. Usually a couple degrees would be considered pretty decent.
	4. Apply new TIM.
GPU vs. CPU
7. Results.
Before: 87C
After: 78.5C
	* Footnote
 Facebook
Facebook Twitter
Twitter
